Passenger Footrest Motor
Where can I find the passenger footrest elec. motor.
I cant get the passenger footrest to move. It was working, where is it located, and how much is involved in getting to it.
Also, I need one of the adjustable slides that hold up the hatches in the cabin. While towing home form mech. shop, one of the hatches popped open, and broke the adjustable slide.
Diamond Member #001
One of the rubber pads (I forget whether it is the upper or lower) on the step is only glued along the top edge. If you lift it up, you will find a removeable access plate. Like Jenks said - check the switch (and the circuit breaker) as well.
The hatches are made by Bomar, but your best bet for a replacament part might be a call to the Tech department at Formula.
