Go Back   Offshoreonly.com > Owner's Forum > Formula
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-04-2008, 03:55 PM   #1
Another problem for the 292!
Well I got good, bad, and worst news. I'll start with the good.
Good News- Sea Water pump is fixed on the port motor. The impeller was completely destroyed, just pieces were left, luckily I found all the pieces. Overheating problem solved.
Bad News- The brass housing was scraped and gauged out, so had to replace that as well. Add another $200+ to the bill.
Worst News- The alternator on the starboard engine went coming back from the sea trial. Pulled up to the dock, tuned both keys to shut off the motors, starboard motor kept running. Traced it back to the alternator. Add another $200+ to the bill.
All in all has not been a good week.
Splitdecision271 is offline   Reply With Quote
Old 07-04-2008, 07:37 PM   #2
RedDog382's Avatar
'99 Formula 382 Poker Run Special/'05 Formula 260 SS
Look at the bright side ... the new style plastic housing pumps flow more water than the old brass style and it's easier to replace the impellors. The new alternators have updated electronics in a smaller package without the big hump on the back. It is easier to work around. And ... a tow in would have cost you more than that.
On the down side ... I would do the same updates to the other engine. The impellors definately have a life span. The same of the alternators. I had the original alternators from my '89 311 engines. Last year, I had problems with the sandwiching bolts backing out and eating pulleys. I replaced two, but then one alternator desintegrated. When the bearings get worn out, the vibration walks the bolts out.
"ENJOY THE VIEW!"
RedDog382 is offline   Reply With Quote
Sponsored Links
Old 07-05-2008, 01:13 PM   #3
Toxic FORMULA
mopower's Avatar
1989 Formula SR-1 272 t/540's
Replaced my engines four years ago along with starters , alts, fuel pumps , seawater and circ. pumps just to be on the safe side
You can never have too much horsepower or money...It's just hard to have both.
mopower is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
91 292 Sr-1 Treads Formula 11 12-14-2007 11:55 AM
04 292 problem help! NICKM Formula 7 06-20-2007 05:14 PM
292??? zoomer Formula 17 01-28-2005 09:55 AM
pushrod problem + cylinder head bolt problem timucin General Q & A 25 12-05-2003 01:00 AM
Latham on a 292 Mark D Formula 4 08-17-2003 11:01 AM
Search Engine Optimization by vBSEO 3.2.0
