NEW DASH opinions.....
#41
JB Marshall
trip2 did you get the panel from the same guy as t500? If not who can you recommend? Please post pics....
Thanks,
JB
#42
21 and 42 footers
JB Marshall
t500 you did go from a raised panel to an all flat panel for the center dash right? and the only needed change was the locaton of the latch on the back?
#45
21 and 42 footers
Mine was already a flat panel. I tried to take measurements for Steve (Innotech) to install the bar/latch piece on the back of the panel but found a better way. When you get the panel back from Innotech, install it on the hinges so it's mounted in the dash without ANY gauges. Apply epoxy/glue the the flat portion of the latch, clip it in where it will meet the dash, then close the panel while holding the catch/latch piece through the tach holes. I only needed to hold it in place a minute or so til the epoxy setup a little. Once it's dried it's in the proper place and you can remove the panel to start installing gauges.
