Winterizing Quetions 1989 272 t/454's
I change the oil before I winterize, sucking the oil out the dipstick.
Have to be careful when trying to use the outdrive muffs when winterizing. Antifreeze is heavier then water which requries more suction to pull the antifreeze through the outdrive. Some boats just can't do it and end up overheating. Doesn't matter which technique you use, everyone should be watching their temperature guage. If you ran into problems I would definately go with phragle's suggestion. Make sure the antifreeze is higher then the motors and let gravity do it's job. See winterizing boats is educational as well. As far as fogging the engine, I simply add a little outboard motor oil to the new fuel filters before I install them and that fogs the engine while I'm running the antifreeze through each motor. Exhaust should get very white and smokey, the more smoke the better.
Anyways, Ok so is there a diagram or something I can look at to figure out which hose it is?
