Where to mount gps sounder
Just bought a Garmin 540S plotter with sounder< I would rather mount the sounder in the boat rather than on the outside, Does formula have a good spot in the hull to mount this inside? 2002 Formula 312, fastech
I have a '98 312 and a Gamin also, I tried the hull in the engine compartment and could not get it to work. I also tried the area under the step in cabin area by the sliding door, it also would not work. I was told you would have cut a hole in the white fiberglass grid system that is bonded to the hull to get the transducer to actually touch the hull surface.
Another method of testing is to fill a zip-lock bag with water and put it against the hull surface.
Does anyone know where the factory installed transducer is located on a 312?
If you find a location that works please reply.
