help gear heads........
not my formula, but my old boat i am trying to sell.
89 454 carb engine
blows big time smoke out starboard side exhaust,
open pipes, not twined.
only after high speed run, then shut down and re start.
doesn't smoke without being turn off.
no blow by on crank vent in valve covers, either side
i am hoping valve seals on one bank.
waasss up
89 454 carb engine
waasss up
89 454 carb engine
waasss up
89 454 carb engine
waasss up
Burnin' Love
thanx for the replies,
it's blows ALOT of smoke, will a seal leak that bad?
my local engine builder/friend fiqures it's a guide if it leaks real bad
I need to pay someone to repair this,
should I bite the bullet and pull the head?
do i need to take off intake to remove head
Where To
Dave
Hopefully you won't find that. If there are no cracks, a good head overhaul should be about 400 bucks each.
took the valve cover and exh manifold off, changed the seals.
none were damaged or dried up.
lots of water in exh manifold and one cylinder pumpd out a little water when aired up to change seal.
heads coming off tomorrow,
sure sucks on a boat for sale, already lost one sale,
On the bright side, got the Formula out of storage today,
cleaned it up and checked and lubed etc,
flashed up instantly on 1st hit of the key....gotta like it
Where To
Sorry to hear the bad news...Might be good that you caught it this soon though. You will feel better knowing that someone will get it in much better condition.
On the Good note...The Formula is out and running with no problems! 50% is better then 0%!!
Dave
Dave
