Seat rocker switch
Seat rocker switch
I need the black rocker switches to raise and lower my seats. Formula only sells them in white now. Does anyone know where I can buy them in BLACK. I would even consider a good used one.
Charter Member #415
It is a McGill switch,DP.DT,CO.SR.That means double pole,double throw,center off,spring return.6 terminals.You have to cross over the upper left terminal to lower right terminal.and upper right terminal to lower left terminal. If someone has a McGill contact,I think I can supply a McGill model # from an old switch.
