Go Back   Offshoreonly.com > Owner's Forum > Formula
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-23-2009, 08:59 PM   #1
Formula 303 SR-1
For those who have removed their Silent Thunder box......
...what does it look like under there? Are there unfinished surfaces? Any surprises, or is it as simple as removing the mounting bolts and dropping it down? I looked at mine and it looks way to easy. I don't want to get into a project to then have it mushroom into something unexpected. What feeds the exhaust into the box?
Any insight is much appreciated.
BowenCT is offline   Reply With Quote
Old 10-23-2009, 09:14 PM   #2
AIRFOIL292's Avatar
1991 292 SR1 FORMULA
Smile
Should be a finished product.The boat was built and the they added the platform on.My was off when I purchased it and had a custom one made by extreme marine.Good job they do.Hope this helps.
AIRFOIL292 is offline   Reply With Quote
Sponsored Links
Old 10-24-2009, 11:32 AM   #3
Charter Member #415
1968 Switzer Shooting Star,1967 Switzer Shooting Star,1963 Glasspar G-3
Very easy,only a few bolts.You can do it alone but a buddy comes in very handy. Most folks just put the bolts back in the holes. Don't forget to put clamp on rubber flappers on the tips.
Magicfloat is offline   Reply With Quote
Old 10-24-2009, 12:10 PM   #4
Secret Formula
1988 formula 311 sr-1
When I pulled mine off the sealant used between the box and the transom pulled a little gelcoat off with it. It was no big deal but I did have to re spray the transom. The gelcoat behind the box was also very discolored.
454captiva is offline   Reply With Quote
Old 10-24-2009, 01:10 PM   #5
Formula 303 SR-1
Quote:
Interesting. That's the kind of info I'm looking for...........the unexpected.
Thanks for all replies.
Old 10-24-2009, 04:49 PM   #6
wantsa311's Avatar
1995 Formula PC 34
I don't think you'll have that problem. The Silent Thunder on a 311 is very different from a 303. The top half of yours is all part of the hull so you are really just dropping the bottom. The whole thing comes off with our 311's.
A girl at my marina dropped the bottom of her Silent Thunder on a 336. No problems, she has 502's, very loud.
wantsa311 is offline   Reply With Quote
Old 10-24-2009, 04:53 PM   #7
Formula 303 SR-1
Quote:
That's right. Good point.
Old 10-24-2009, 11:43 PM   #8
Charter Member #415
Everyone should realize there is a big difference between the older boats and the new boats regarding Silent Thunder.Just be sure which model you are asking about when you post a question,cause the answer can be very different.I responded to a 303 owner,my answer would be different to an older boat,just an FYI.
Old 10-27-2009, 04:52 PM   #9
anewway's Avatar
'89 Cigarette Cafe Racer
I didn't have any issues removing mine, but its not that old, only a '98.
There were 4 (I think) bolts holding it to the swim platform and two to the transom.
They had a sealant around the actual exhaust ports, so I had to wiggle and pull on it a bit, which had me nervous, but it finally came off.
I cleaned up the excess, put on some rubber flaps and away I went.
That coupled with the Stainless Marine exhaust really opened up the rumble.
anewway is offline   Reply With Quote
Old 10-28-2009, 09:43 PM   #10
jiffy292's Avatar
89 311
how much do those extreme marine platforms run new?
jiffy292 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
