Formula 255 Liberator
Here's what it looks like on a Merc 5.7...this is a pic of a 355 in my brother's '83 Formula F3.
Notice the "J Tube" bowl vents....also how close the front bowl is to the T-Stat housing....double check this.
If you can make it work with out too many gymnastics this is for sure the best way to go.
WOW talk about close clearence!!! Thanks a ton for the pic, that makes a world of difference and now that J-tube makes sense. I think I intend to clean the motor and see if she runs like the seller and claimed and as soon as I establish that I have a solid motor on my hands, we'll start the modding process. Next question... Hull thru pipes? Is there a way to route them straight out the back using my existing manifolds?? Should I post up pics for reference?
Hull thru pipes?
Don't do it...it's not worth the trouble and the noise will drive you nuts. With a stock motor you might even loose power.
You got to trust me on this one. There are a lot of things you can do to make your boat run better...thats not one of them.
sprink, I suddenly feel like a little boy trying to rationalize a BB gun... They sound amazing and your probably right, the massive drop in back pressure isn't going to be nice to my power which is already lacking with an OMC 260. Really?? No Hull Thru Pipes??? PLEASE!!!
sprink you've successfully rained on my parade and my sincerest apologies to whoever's thread we have completely and utter high jacked. New kid with a bird here and I'm excited
I'm going to have to disagree on the through hull exhaust! If your running a stock engine up to maybe 330 hp then you most likely won't notice much. Beyond that it's almost manditory. I've got a 242 with the silent thunder platform with a 525 hp 440 bbc. I gained about 1-2 mph by drilling the bottom of my platform with 2 4" holes on bottom of each side. This reduced the back pressure and didn't allow the platform to fill with water, so it would be lighter. The exhaust hole on the through hub exhaust is small and restrictive. Dennis Miller goes into some detail on this and in smaller engines the venturi effect from the prop can actually help on smaller engines but on more powerful engines thru hub is going to be an hp killer.
As far as rot caused be the exhaust ports, I would disagree there as well.. These are above the water and if sealed right they are not going to leak. And last, the noise isn't bad at all, it all depends on what you like.
I kind of look at STRAIGHT thru hull on a stock 260 HP engine
like headers on a stock smog engine in a car...not worth the effort.
You should see all of the gymnastics the thru hull go fast guys here in Florida are going thru just to comply with the USCG/FMC noise rules.
I'm just sayin...
Sprink, I'm not gonna disagree with the Noise rule issues, a good friend of mine has a 2900 Endeavor with twin worked 454's (535hp and 538hp) that has captains choice due to some of there sheriffs around here. Plus Thru Hull is a big expense I likely don't need on a stock 260OMC. With that said, a 383 would definitely get the treatment. I'm pretty sure the noise won't ever bother me... My cars and bikes are pretty load and I like it!!! This year is all about getting the boat in the water and enjoying it. She'll see more wax then performance parts
