311 with trs drive
[email protected]
My '88 has the old original Perko strainers. I removed the lids, then drilled and tapped to 3/4 '' pipe. Use a short brass nipple and a pipe to hose adapter. Close the pick-up valves and fire it up. Just watch you don't suck the hose closed from low water pressure. After you're done, install a pipe cap in place of the adapter. It works for me.
BC
BC
BC
BC
Btw if you do this make sure they are capped if not water pressure will cause water to come in the boat when at speed!
