Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Gold Member Gold Member
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    Angry Only going up WHY?
    OMC stringer outdrive only will go up, but won't go down under power. Isn't it the same trim motor? And the motor is a chevy 350 (omc 260) it won't circulate water? Is there a way to bypass the water pick ups and check only the water pump? What if I pull the thermostat out?
  2. #2
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    Forgot to mention, when I push the tilt switch down, it kills the motor if its running, but the outdrive comes up as normal when the tilt switch is pushed up, motor stays running fine, no drop in rpm
  3. #3
    Join Date
    Aug 2009
    Posts
    125
    Does your Volt guage drop when you try to go down?
  4. #4
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    I didn't check. I'll do that next. I don't believe it does though... What would a voltage drop mean? What would a lack of a voltage drop mean?
  5. #5
    Platinum Member Platinum Member sprink58's Avatar
    My Boats:
    1979 Formula 255 Liberator...My 4th Formula
    Join Date
    Jan 2011
    Location
    West Palm Beach, Fl
    Posts
    2,097
    My brother has had a few of these stringer drives in the past...I'll ask him. Seems that I remember him telling me about several different solonoids and that they were just like the ones that Ford used to use as remote starter solonoids...cheap and available everywhere. Check to see if ther is an up solonoid as well as a down solonoid...if there is that could be your problem. I will ask and get back to you here.
    IF YOU WANT TO HAUL COAL...BUY A BARGE
    BUT IF YOU WANT TO HAUL ASS.....
    BUY A FORMULA....
  6. #6
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    Thanks sprink! Is that solenoid on the outdrive on on the transom wall inside the bilge?
  7. #7
    My Boats:
    Join Date
    Jan 2011
    Location
    West Palm Beach, Fl
    Posts
    2,097
    OK...spoke with my brother...says that as he recalls there are 4 solonoids. I don't know where they are mounted but could be anywhere. The way to verify if that is your problem is to locate each and put a jumper wire accross the solonid lugs to see if the pump runs down when you jump it...if it does then you know. You can buy those solonoids at BOW or West or even Auto Zone...they are the same. Shoudn't be more than $10~$12 or so...he said always carry spares because when they fail you are stuck.
    Hope this helps.
    BUY A FORMULA....
  8. #8
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    Thanks sprink, I'll check them out and it's probably that. Any idea why water would come out of the thermostat housing but not circulate through the rest of the motor?
  9. #9
    My Boats:
    Join Date
    Jan 2011
    Location
    West Palm Beach, Fl
    Posts
    2,097
    Quote Originally Posted by machloosy View Post
    Possibly a stuck thermostat
    BUY A FORMULA....
  10. #10
    My Boats:
    '85 Supra Sunsport
    Join Date
    Jan 2011
    Location
    Syracuse, NY
    Posts
    903
    I tested hoses?thermostat etc and the diagnoses is that the impeller isn't pushing in sufficient water. So... I have a new impeller kit, I need help getting this stringer outdrive apart. Anyone that has dealt with this drive?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
