ST flaps?
Old 08-02-2011, 08:32 PM
Default ST flaps?
Can I remove the rubber square flaps on the silent thunder swim platform. There is another set of flappers on the inside where the exhaust goes thru the transom.
s022mag is offline
Old 08-02-2011, 08:37 PM
aquaforce's Avatar
I was thinking of the same thing. Mine is not running yet and the only reservation I could think of was if there was a lot of backwash coming down off plane that would get into the platform suddenly. ???
aquaforce is offline
Old 08-03-2011, 08:51 PM
masi242's Avatar
I ran mine with out them with know trouble, you can also drill a couple of extra holes under platform to help any extra water drain. Inside the platform there is a piece of fiberglass that acts as a baffle inside, if you look inside you will see it maybe 8-10 inches in, many of us cut that out for more sound.You will not have to worry about reversion as the exhaust sits a little higher in the platform.
masi242 is offline
Old 08-06-2011, 11:27 AM
Cool. Thanks. That's the first thing I'm doing when I get her home. Darn tranny needs rebuilt. Mine already has the holes cut out on the bottom and I believe the baffle is cut out too. Just looks hollow in there.
s022mag is offline
