anyone replace fuel line from tank to fuel pump on sr1 ( 336)
I found my fuel line somehow got pulled ahead and rubbed the waterpump/fuel pump pulley. almost wore through !!
is the access panel in the floor under teh bench seat the access to the tank fittings?
thanks
Ramb
thanks
Ramb
Ramb,
You should be able to get to them through the panel under the seat and through the round access port on the firewall above the steps. I just did mine on my 303, you should have a very close layout. It was Not easy to get them off the barbed fittings, it can be a knuckle buster.
Good luck.
Good luck.
1 Post
Fixx
i have the same boat,,evereything is accessable from the access holes as mentioned above.. just make sure you use double wall uscg hose and not hose from your local auto parts store..double clamps at each end also..
