hey ya'll
Do you have an oil cooler?
Not yet, looking into one though. Looking at the air cooled ones, as I'm not sure on how to plumb up a water cooled type. Plus, since I'm not using a water pump on this engine, I'm not sure if the pump in my drive will push enough water for everything.
As far as you bumping one up to squeeze harder, did you turn more rpms or just bump up the power out put? I'm still new to boat engines, but it seems like if my motor is running 150 to 165 degrees, oil temps shouldn't be an issue..??
I'll give ya'll some more info to guide me upon, here's my engine specs:
1995 Gen V 370ho 4 bolt block, forged crank and pistons, 7/16" rods 325cc rectangular port heads
Honed and new cam bearings
crank turned 10/10
reused the pistons after cleaning them up and used Hastings Moly rings
Heads had .030 milled,v valves ground and vacuum checked and magnafluxed, springs seats were opened up for a 1.850 spring, removed factory non/adjustable rocker studs and installed arp rocker studs, 1.7 ratio Cam Dynamics roller rockers
Using Mercruiser #1622 roller cam, that I degreed in to a 106 ICL, retrofit roller lifters.
crank turned 10/10
Well I stroked it from 4" to 4 1/4", jacked up the compression to 9.6 and punched it for 496 cid. With the extra squeeze on the bearings from this power increase the oil temps go up with it from added pressure on the bearings. Rpm's won't go above 5,500 for the most part but the cam is rated at 6,200.
What will your compression ratio be? As this goes up the oil temps are what determines the cooler need.
THat motor stock from merc had a small water cooled oil cooler on it. Normally on the port side mounted down around the pan rail area. With a typical marine CR the stock one can still work for you but if you mod the engine beyond, I think I have been told 70hp, then the cooler needs to start ramping up. The impeller in the drive does just fine on the Alpha to get the water up through the coolers and into the engine so I would expect yours to do ok.
I suppose you could use air cooled but I haven't seen it done.
The longer the throttles are on the dash the faster the oil heats up. The engine can control at say 165-180 and the engine oil temps exceed 230° fast with hard driving or high HP.
My compression was 8.6 stock, and with .030 off the heads, I doubt its more than 8.7 now. I plan on propping the boat to around 5k wot, but have been told my bottom end will take 5500 no problem. my goal is 70 mph gps with this old girl.
i see what you're saying about the engine temp and the difference of the oil temp. Looks like I'm gonna hunt up an oil cooler, as my block didn't have the cooler adapter or oil filter adapter on it when I bought it.
Thanks for the input, this is my first boat and quite a learning experience.
This being my first boat, its still new and fun, also it does hurt to make mistakes that cost time and money. I f I had known I was gonna put a big block in her, I def wouldn't have bought a new alpha replacement, instead I would have started the bravo swap.
I know about learning this stuff. My engine building has been a huge learning curve. Coming from drag racing I expected an easy slide. I learned very fast marine is a different animal.
I had nearly the same interest; 70 MPH with a build up and 500 HP. I can tell you that it takes 500hp or better with at least 9.1 CR to hit 70 with 24' and 24 deg deadrise. If you want 70mph you can do it with an Alpha. Holding that speed for long durations will really strain it but all the 87 production 7.4l were paired with Alpha.
Same here! Wow, what a difference, and learning real quick how basically de-tuned the engines are. I know full well with my engine, with just a lil compression boost, more timing than the 30 degrees I plan to run, and good exhaust she would make a nice street motor!
I thought the 223ls was really a 22' with 23deg deadrise??? he swim platform was counted in the total length for 24ft?
I'm estimating 475hp, really hopes it hits the 70mph mark. if not, after paint and interior, a bigger bumpstick and headers oughta do it! I'd really like headers now, as my exhaust is really keeping this engine from getting past my estimated output... But I'm already past the max power for my Alpha anyhow..
But you know what...as long as you are on a lake and not too far from home it's no big deal. As for me...I cant afford to be 20~30 miles offshore halfway between Florida and the Bahamas and have a drive failure.
My brother in Destin is doing a '83 F3 with a 454 on Bravo I now....gonna be interesting how it turns out. there is a dude down here that has one (F3) with a 454 on a Bravo...runs 65 easy but porpoises bad over 70. He's running a 25" Mirage 3 blade with 1.5 gears.
I know of a certain 242 as a reference to the speed and required power. Since your running/wetted length is less and boat weight is less a little lower power would be required for the same speed.
Simply put, marine is about making power under full detonation conditions. Tough challenge. Most high HP marine engines could be cammed different on the street to make some serious ground shaking power.
Don't sweat the Alpha too much. It will hold with you for a good while. I got all into getting rid of my Alpha when it had one more issue than I cared to fix. Swapping out for the Bravo1 and getting everything it needed and doing it right got into some money and time. I have changed my 242SS to a Bravo1 system since I stroked this 496 but the previous Alpha was living fine behind a 400hp 454.
Sprink, you're 100% right. My lake isnt too big, so even if i get stranded bc a grenaded drive or engine, I have plenty have crackers and beer onboard to survive on before I get a tow. Now if I was in your shoes, I def would have a different outlook.
Aqua- I know my static compression is about 8.6/8.7, that was the reasoning of me advancing my cam to a 106icl from the factory 109, wanted to build some extra cylinder pressure without milling a ton off the heads or swapping pistons. this engine has been a budget build, but with decent parts. I have less than 5k in the engine still, even with purchase price included. It was a running engine when I bought it, minus the fact #6 had 100psi. which turned out to be a valve issue, but since I had it tore down, and the crank was a little iffy, decide to hone the bores, cut the crank and a new set of rings was in order.
