Break Out Another Thousand
#31
thanks guys we still have some issues to work out I had a leak in the outdrive so we fixed that last night and found out the the bearings in the upper drive need to be replaced.I have a pair or 4in exhaust tips to install and some vinyl trim pieces to make. The biggest issue is the motors only turning 4300rpms wot. That's with a aluminum 19 pitch 4blade prop so I think I need to find a 17pitch.
#32
I'm not quite sure why I'd need a smaller prop all of the info I have found is that boat with a 260hp SBC should turn a 19 I have a little more HP and can't turn it with just me in the boat.
#35
Our hulls really don't like a 4 blade prop. The 4 blade tends to lift the stern more and we need bow lift to expose less hull to the water. Formulas run deep as a rule... that's why we get the better ride..to get the speed and RPM up we need to get some of that hull out of the water and the 3 blade does a better job of that.
My brother has your boat and a 19" Mirage Plus 3 blade puts him at 50 at 4900 RPM with a 300 horse SBC.
#36
It sounds like the mirage plus is what I need I'm not sure why the 4blade was recommended to me but hopefully I can exchange it for the M.plus and pick up some rpms and maybe some mphs :-) thanks for the info.
