Water in cabin floor compartment of 353 fastech??!!
Lot's of great troubleshooting advice!! I have installed a plug in the drain to the bilge. I have put dye in the fresh water tank which is in the bow. The anchor locker is draining overboard, so I may fill it with water and a different color dye also. No water since pumpout yesterday, so I will check after next rain as well. Thanks!!
Welcome to the Formula club. You will love your 353! Don't forget to post some pictures of your new ride!
Peace is that brief glorious moment in history when everybody stands around reloading.
Here are quite a few threads with this same issue.
http://www.offshoreonly.com/forums/f...nder-step.html
http://www.offshoreonly.com/forums/f...abin-step.html
http://www.offshoreonly.com/forums/f...ps-solved.html
http://www.offshoreonly.com/forums/f...-my-311-a.html
http://www.offshoreonly.com/forums/f...indsheild.html
http://www.offshoreonly.com/forums/f...lige-step.html
http://www.offshoreonly.com/forums/f...step-read.html
I recently purchased a 2004 353 fastech. As you enter the cabin, there is a flip up step that opens to a gel coated compartment at the bottom of the boat. This area is always full of water- I empty 1-2 gallons a week. there is a drain hose that appears to be coming from the head compartment, but that is definitely not the source of water. There is a drain in the compartment bulkhead that drains to the bilge. This drain has a tethered plug. Should this plug be left in or out? I have tried running a hose in various locations, but have not found the source of water accumulation. The cabin sink drains directly to the bilge. Does anything else drain below the cabin floor? The humidity is creating a mildew problem in the cabin. Thanks for any advice on this subject!
Billy
Baja..Im having the same issue (as are all other Formula owners Ive talked to) and it got me how water would come up from bilge but not drain back..so plugging that 'drain line' (that doesnt drain..should rename it fill line) in the aft part of that small well under the step stopped that issue?
