353 500's vs. 525's
I have a 2000 353 with 454 500hp heads cam and a 250 single carb blower set up. I dynod and got 610hp 5lb booste.
Low fuel two people low wafter tank. The boat also has neutral extension boxes. GPS BEST SPEED trimmed all the way was 83mph! I don't know how some of these people are getting these speeds with 470 500 hp?? Maybe I'm doing something wrong.
Where To
Well, first of all, what are the torque numbers? Secondly, what is your max RPM in the boat compared to the dyno?
Boat test at 90 with 600's is very generous....85-87 is the real number.
Dave
I'm on GPS garmin and handheld GPS, best so far was 84.7, have not got it there again. Always 83.5-83.8. My GPS speedo says 86, and there is no way the boat does that.
You have the first Gen hull? I do not have info about shorty performance on that specific hull. I know on my year the shorties do not add performance with my set-up, there was an OSO member that tried it and the boat did not run out well. There is an 06 353 with exact same running specs/hrs as mine in LEOPA but does not have ITS and the boat did not touch 80. There is something to having boxes on the 353 to get some speed out of it. Have you tried 380 K-Planes? That is next on my list if I can get the clearance.
Boattest.com maxed out at 80,5 mph with 525 and bravo drives. When I wahced that test on YouTube it looks like they never got the boat "out of the water" ...
It is the 2012 353 test I am referring to
It seems that you need big power 650 + hp and boxes / shorties to get the 353 to real fast :-)
Marcus the owner of the mentioned 353,told me he is going to upgrade the engines with Whippels 900 hp ++
This year. Then it starts to get realy interesting ;-)
