No Power
No Power
I have an 89 272 with twin 454's. I just got around to getting it ready to go out for the first time and I knew the batteries were low. I started both of them two months ago. Had to let it sit because of military training. Anyway, I put the battery switch to all. I put an instant charger on the starboard battery and it cranked a few times. Cables on the charger got warm. I left it on there for a couple minutes. Now I have no power to the boat. Did I fry the batteries? I checked all the cables and all connections are tight/clean. Thanks for any advice and no smartass comments please.
Did you check the main breaker where the harness plugs into????
If that hasn't tripped, try this article..
http://www.sterndrives.com/no_crank_condition.html
After checking all fuses, I thought I toasted the batteries but for some reason the instantcharger got toasted!? I put her on a trickle charge and a while later the twins came to life...so relieved. Thanks everyone!
