Almost there ......
Now thats cooking congrats.
boxes and more prop with 1" shortys will help ya, my buddy (Lake Effect) 98' 353 Formula has 509's 7 lbs boost, 1" shortys with 36 labbed 4 blades best of 107@6000 now with safer tune easily went 103 with a loose bonnet down 2 lbs boost, prochargers are bad azz.....
he can give ya advice if needed... smart dude
pretty much dead on the same ..... both are GPS ...... they both dynode @ over 840 each ..... Bob Madara's numbers called for ez 900hp but the dyno we used has a history of being 8-10% short on the numbers ... meaning his motors are usually stronger than other motors that showed bigger numbers somewhere else .... Bobs usually pretty conservative on his numbers and pretty much always right ..Cant ask for a more knowledgeable or Friendly guy ......m
if you are making that much HP, I am gonna say with proper setup that would be easily 108 mph boat.....
[ATTACH=CONFIG]512147[/ATTACH][ATTACH=CONFIG]512148[/ATTACH]
