Formula 271 1997 performance.
Hi I have recently bought a 271 sr1 with a 502 mpi.
It has got a bravo 3 drive on it and not a bravo 1.
What sort of top speed should I see from this set up.
Cheers Dave.
Cheers Dave.
I'll guess 55, but your hole shot and docking will be better, if you want the last 5/7 mph bolt on a B1
Hi all I have an option on a Bravo 1X from the bravo 3 that I have already can I have some opinions please.
what is the holeshot like on a 271 with a Bravo 1 setup?
What is a suitable prop for the set up?
Currently running a 26P bravo 3 set of props.
whole shot will be slower then the bravo 3, if u plan to tube n such leave it alone, if you have a buddy you wanna keep up with make the swap, I am not sure what u will need for a prop? my 93 had a 23 mir on it, I think the fastech hull changes the prop a bit, I notice alotta them are spinning 4 blades
