272 Alphas to Bravos???
Anybody done this on a 272? Looking at an alpha boat and I have complete bravo setups to convert. I read it was only 2 holes difference but do engines have to come out, do I need to change cables etc?
Definitely going to have to pull engines to get the drives completely off.
Obviously the Bravos are a stronger drive but you are going to lose some speed switching to the them. Atleast that Is what my research has always came up with. Is your 272 twin SBC or BBC?
Yes take engines out, drill two holes, you wont need the shift interrupter anymore with bravos. Are the alphas counter rotating? If not you will need/want to change the shifting to counter rotate the bravos, cant remember if all shifters can do that.
Good Luck !!
