Im converting my 1988 320 hp efi small blocks to carb. Recommend?
I went through this exact swap a few years ago on my 272. I used Edelbrock Performer RPM Air Gap intakes with Quick Fuel 650 with manual secondary's. Your also going to have to change up your fuel system to bring the pressure down for the carbs. For simplicity I went to mechanical pumps mounted on the engine. just take off the block off plates and you should be good to go that route if you choose.
Good luck on the swap. The EFI was cool but without a way to troubleshoot issues and no longer being able to get parts for them it was an easy decision.
Im now looking for a fridge to that is missing from my 272? any recommendations.
i see a norcold new for under 200 thats 12v and 110vdc?
what will fit/work. Should i have a separate battery just for that?
