What is the fastest 272SR1
Mopower, it should run with those motors. What sort of drives and lowers are you running? I am running XR uppers with IMCO 2" shorter lowers.
Even with the 30 Bravos this thing accellerates like crazy, I can go from 25 to 90mph within a marked quarter mile.
I am confident I can reach 100 mph if I put on some decent exhaust and the right size carb for my application. I am pretty sure I would realize about 100-150hp each with these changes.
By the way it is still a family boat and runs strictly pump gas, no race fuel even in the poker run.
Toxic FORMULA
Originally posted by CayFomula
Mopower, it should run with those motors. What sort of drives and lowers are you running? .
And yes , I do have a spare drive in the garage .
Big hooks in the hull???
I never noticed any hook on my 272. I know my 357 doesn't have a hook because I checked after some improper storage on the trailer. Did the 272s have an engineered hook in the hull?
Toxic FORMULA
Russ SR1,
No , not yet. Was out last Sunday for the first time and had a K-Plane that wouldn't retract all the way
. Fixed that Saturday night. Went again Sunday and backed it off the trailer and found out I couldn't get the left drive out of reverse . Nothing serious...an easy fix...took all of ten minutes...AFTER I got the part today .
The plastic cable end that holds the sheath broke.
bford1,
My 272 has a hook in the last foot between the outside strake and the chine. It's very obvious , as the 2 inch strake disappears into the bottom. Just put a straight edge on it and you can see were the hook is
bford1,
I hit a new top speed of 97mph this weekend in the annual poker run/race before I broke a drive. This was with two people and a full tank of gas, still running the same props, drives and motors however I have upgraded the exhaust to the Stainless Marine Gen III exhaust with dry tailpipes and bigger carbs. I have also gone through the hull complelely (replacing stringers and bulkheads, adding two small stringer under the engines and glassing the hull and deck together), repainted the hull.
I am convinced she would have hit 100mph this weekend if the drive had held up till we burn off some fuel.
The best part is we still won the race with one motor, we were able to maintain 60mph on the one and all of the other real fast boats broke so with the lead we had we still won.
wow is all I can say, Ive always thought the 272 handled well am I missing something
formuladude312?
UNBELIEVABLE. You are the man Cay!!!! That is running for a 272
