Prop Rotation on a 35
1 Post
Re: Prop Rotation on a 35
Mine is a oo twin step an they turn out, called fountain and they said in 00 they turned out on the 35,87 on gps .I never seen a fountain turn out before, I am going to try turning in this year to see if there realy is a differance, I had a Velocity no step and they turned in and had no problem around dock and a 32 fountain stepped turning in and no problem.
thks Joe
thks Joe
Ok we will try it both ways. Thanks for the info guys.
And Beak Boater its my new pleasure boat. So the race boat will stay on the trailer more.
Charter Member # 545
That could be a problem. Once you get used to the Fountain experience, you may not want to get back in the Formula. A little birdie told me that someone left the drain plugs in and it sat and filled up with water so deep in the bilge that you had to take a cutting torch to get the motor mounts out of the boat
props
I have a 93 35lightning props turn out 3000rpm's close to 50 3500rpm,s close to 60 top end on a cool day in the fall has seen 80 on gps with hp500,s 28 inch bravo,s
