Factory jumper cables >
Old 04-27-2007, 12:41 PM
Downtown42's Avatar
Default Factory jumper cables
Mine plug in by the floor on bench seat. Question:
If I hook up my battery charger to the cable ends, which battery will it charge? Does it send current just to 1 battery or 2?
Downtown42 is offline
Old 04-27-2007, 02:39 PM
Were doomed!
Wally's Avatar
I would imagine it would just send juice to one battery...if it did more then one battery at a time then there would be no reason to have a Battery selector switch as the batteries would be connected all together (linked in parallel)
-Wally
Wally is offline
Old 04-27-2007, 03:11 PM
rjcardinal's Avatar
Depends on the position of your battery switch. If you set it to both, which connects both batteries in paralell, it should charge both batteries.
Ron
rjcardinal is offline
Old 04-27-2007, 03:34 PM
Back4More's Avatar
Won't the shore power charge both batteries?
Back4More is offline
Old 04-27-2007, 03:51 PM
Were doomed!
Wally's Avatar
Shore power is usually wired straight to the individual battery....so if you have 3 batteries onboard then you probably have a 3 bank charger....you plug in shore power and turn on the charger and its charging...realy has nothing to do with the swicth...unles you have the swict set to both in which case the shore powers bank will be probably fighting each other....
-Wally
Wally is offline
Old 04-27-2007, 04:35 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Ron
Bingo!
The cables go directly to 1 of the batterys. Up the the switch position to determine if you send the juice to the other batterys.
US1 Fountain is offline
Old 04-27-2007, 04:40 PM
tomtbone1993's Avatar
no one has a Volt meter, and can do a little Myth Bustin?
tomtbone1993 is offline
Old 04-27-2007, 05:38 PM
Rob
Strip Poker 388's Avatar
if ya would quit hooking them up to your peanuts it wouldnt drain the batteries
I would think the house/#1 bat.thats the way mine is
Strip Poker 388 is offline
Old 04-27-2007, 07:43 PM
BZ
BZ's Avatar
You cheep azz, just buy and on board charger and then you won't have to rig up this screwy charging system...LOL...BZ
BZ is offline
Old 04-29-2007, 05:49 PM
Downtown42's Avatar
Yep it goes to the #2 battery. All went well.
Quick Reply: Factory jumper cables
