anchor light
Just in case the images don't upload check out Boatsafe.com
Will You Be Seen In Time?
Operating at night (or in reduced visibility) can present some special challenges. Not only is your depth perception lessened, bright lights on the shore can cast misleading reflections on the water and if you wear glasses, or worse yet bifocals, you simply don't see as well at night as you do during the day.
It is not only important that you be able to identify other vessels operating in your proximity, it is equally important that other vessels see you.Most recreational vessels are less than 30 feet in length and, according to the Rules of the Road, shall be equipped with navigation lights. These lights not only have a certain arc through which they can be seen but must be seen from a minimum distance. The following lighting requirements are for recreational vessels less than 12 meters in length. (approximately 39.4')
Light Arc Color Visible
Range boatlites.gif (3948 bytes)
Masthead Light
225º
White
2
Starboard Sidelight
112.5º
Green 1
Port Sidelight 112.5º Red 1
Sternlight 135º White 2
The arc of the lights and color allows you to determine the direction a vessel is moving. How good are your lights? You should test them to see how visible you might be at night. Whether on a trailer or at the marina, switch on your lights and see how well they can be seen. Walk away from the boat or row away, if you are at anchor or at a mooring, and see how visible the lights are as you move further away. How easy are they to see against the background of lights on shore?
Masthead Light
225º
White
2
Starboard Sidelight
112.5º
Green 1
