Anyway to confirm engine hours other than hourmeter????
I'm looking at a 1995 Fountain 32' Fever with twin 454 Mercs. The hourmeter shows 402 hours but from reliable sources I think the hourmeter may have been unplugged. Does anybody know if there is any way to confirm actual hours on the engines? Thanks for your help.
Registered User
If the boat looks clean and you like it do a leak down compression test and that should give you a clue on the conditionof the engines.
Good luck,
David
On a side note, I would certainly want a compression check WITH leak down tests, oil samples for engines, and maybe even oil samples for drives. Best bet for drives would be too run the boat for an hour give or take and drain the oil. Does the owner have service records for you? Just my opinion but hours on marine engines only mean so much. If the boat has been sitting for long periods of time, knowing the hours will become less important vs going though everything on your own (rubbers, coupler, gimbal, cables, and on and on...).
cheers!
jason
SOME MARINE ENGINE COMPUTERS STORE SUCH DATA.
HOWEVER YOURS MAY NOT, IT MAY BE GEN 1 AND NOT
CAPABLE>. YOU CAN USE WATER BOARD TORTURE ON THE
SELLER OR PERHAPS A VULCAN MIND-MELL. I SAW SPOK
DO IT ONCE ON STAR TRAK
Registered User
mach1.i have a 94 fever and when i bough it the owner said that the key was left on and it read543hr,s.he said the hours are around 380.my boat guy took his computor and down loaded the info off my engine computor and got the right hours.383.i am told that any merc engine that is injected has a stored record on the ecm.it allso tells of any fault codes that kick up.hope this help.brad
