Need HELP getting on plane..any ideas??
Like everyone says the Bravo prop will plane much better. It will give you better fuel milage at cruise speed too.
Getting on plane in the 27 Fountain requires full tabs and full down drive.
Now for the trick.
It will plane better with less throttle. It seems hard to believe but in most cases it will. Think about it this way. When you floor it and the nose goes sky high the stern is digging a huge hole in the water. To get on plane the boat must climb out of this hole. Therefore the smaller you can make the hole the easier it is to get on plane. It takes a while to get the hang of it but it will become second nature. What you have to do to acheive this changes with fuel amd people load but you can feel it.
Everything else everyone said is true. A slight letting off as the boat is starting to come over helps greatly. You will get the feel of how much throttle is required and for how long before you let off and let the boat come onto plane.
The first time I had 5 people in the boat it was embarrassing how long it took to get on plane. After I learned the boat even 6 people was acceptable.
Good luck,
Ron
Now for the trick.
Good luck,
Ron
Now for the trick.
Good luck,
Ron
Now for the trick.
Good luck,
Ron
Contact B Blades. He is all over the prop talk post. He can rent you a prop to try.
for what it's worth........ I have 600hp to the prop and approx 580ft lbs and can't turn my 28 Hydro past 4700. Talked to Brett yesterday and he's sending me a 26 Bravo 1 to try. He feels that's the best all around prop for the 27s. I'll have results end of next week.
SeaRay Sundancer
I would try the 26 if i was you. I run a 26 b1, 1.5 bravo, 496ho, and can spin the prop to 68.6mph @ 4850ish rpm i think. Your motor will spin to 5400rpm right?........that should get you upper 70's i think with that prop and get on plane how its supposed to. A 28p b1 just sounds like too much.
