2001 29' fever gas fumes in cabin - help
Cabin smelled but went totally away. Also, my fill neck hose clamps were very loose and weaped a little.
You said you only notice it underway. Do people ride down there while your driving?
Good luck.
Open the access panel under your back seat and check the vent line follow it under the side compartment and up to the vent also follow the fill hose make sure all connections are secure. if all are you may have a cracked fuel tank! last resort.
