Help setting up 2000 38' fountain
2000 38' Lightning with HP500 Carb's, slightly hotter cams, headers, stock Bravo I's (not XR's), 26 hydros (not labbed), spinning in, on the limiters. Run 81 - 82 GPS with two people and 1/2 tank of fuel. I would have expected you to be closer to 95ish with 700HP. Thinking of rebuilding my engines to 700 - 750 HP and adding XR's, so I am very interested in your results. Good luck; let us know how it turns out.
Registered User
sat was fun till i lost my starbord rotor.ran 32 p5 at 5100 at 84 not good. ran today with 29 p5x at 5700 at 90.5 better but still to much slip and needed a lot of trim around 6 or 7. i need a lot more help
any one set this up before.
might try the p5x version of prop, also which way are you turning your props in or out?
38 Tally, I sent you a response in the prop section. You will be much better off with 4 blade and you will probably want to space down 1/2" to 1". Your small steps cannot be compared to the 2000 and newer boats with the bigger steps and higher x dimensions. The 5 blades always work better with high x dimensions but you are leaving speed on the table (Space down 1/2" to 1" 4 blade 29 Hydromotive or Bravo 1)
try some 4 blade bravos, if it will get on plane ok then your drives are not to high, if it wont get on plane you will have to stay with 5 blades are add a spacer to lower your drive. also call throttle up and try some of there loaner props, see if they have any of there new 5 blades they make in house, that will give you what you are looking for
1stfntn
Prop Talk
6
08-18-2005 08:48 AM
