Q's 47 Flat Deck - Ready 4 drives!!!!! >
Old 01-02-2009, 09:04 PM
  #31
Originally Posted by Wahoo ATV
Why did you go from 6s to surface drives? From what I know both are excellent choices.
You are correct... they are both great drives. This boat originally came with trip merc 6's.... I put in a fresh transom and went with the ASD 8's for a few reasons:
- Weight: the 8's weigh less then the 6's by a few hundred pounds per side.
- More speed: In my opinion, it takes less HP to turn the ASD8's then it does a full Merc 6 set up. Guys, this is just my opinion...
- Staggered Set up: To gain more speed I really needed to cut out the third motor and push the props together. If I used the 6's then I'd have to redesign the entire engine compartment... new stringers... move gas tanks...etc..etc.. Instead, I went with the 16" offset ASD8's Now, I can leave the motors all the way in the back stock location... and push the props together at the same time. Check out the pic below... same type of set up.
TeamPSI is offline
Old 01-02-2009, 09:07 PM
  #32
If you don't mind my asking, what did that complete set up cost from Arneson. I am assuming they were new?
Really cool set up. More should try it.
jeff1000man is offline
Old 01-02-2009, 09:19 PM
  #33
I believe it is around 45k to 50k from Arneson for the 16 inch offset system... you'd have to ask Rick for some solid pricing, but that is pretty close.
I can't wait to test it out!!!!! I wonder what docking a 47 with ASD's is going to be like??... should be interesting to say the least...
Q
TeamPSI is offline
Old 01-03-2009, 03:30 PM
  #34
Racer
Racer
Wahoo ATV's Avatar
That makes perfect sense when you think of it. By selling the #6 setup you could also cover most if not all of the ASDs
Wahoo ATV is offline
Old 01-03-2009, 03:58 PM
  #35
Received 1,328 Likes on 741 Posts
Who did the paint?
Wildman_grafix is offline
Old 01-03-2009, 11:46 PM
  #36
Who did the paint?
David from Javidco in brooksville, FL. PM me and I will give you his contact info...
Thanks again!
Q
TeamPSI is offline
Old 01-04-2009, 07:09 AM
  #37
OL40SVX's Avatar
Great looking "flat" deck!!
Not too many green Fountains/boats out there at all!
OL40SVX is offline
Old 01-04-2009, 08:27 PM
  #38
aTX427's Avatar
I think the ASD8 can take more torque as well. Should throw a hell of a rooster tail.
aTX427 is offline
Old 01-04-2009, 10:05 PM
  #39
I am counting on it!!!!!!! it will be wild 2 see what performance comes of this combination. Does anyone have a guess on top speed??
I am thinking from 1000hp to 1500hp per side.... I know this is not a step hull... but very curious to see where the numbers land. Any input?
Thanks guys...
TeamPSI is offline
Old 01-04-2009, 11:40 PM
  #40
1,500....130ish? just a guess
fountainracing65 is offline
Quick Reply: Q's 47 Flat Deck - Ready 4 drives!!!!!
