Forward Bilge Compartment Question
My boat hasn't been in the water in the last two months but somehow water seems to find it's way into this compartment. I don't even use the ice chest in the boat. Where does the water for this compartment come from? I don't have anything in the front 3 compartments either besides the stupid orange life jackets.
What to do? Jack the trailer tongue way up when parked for a week or so and let it all drain to the forward pump area right under the cabin step. Then, dry it out with a vaccum and then use towel to soak up anyting left behind vaccum. Put another towel there and leave trailer as high as possible until next time you use boat. Neighbors will think you're me but you'll have a dry forward bilge until next time. I have seen mine stay dry for quite a long time until rain or if i let water in rear make it's way up front...
Sux.
Registered User
Hi James,
I had the same problem with my 35, I think I figured it out. The rear bilge where the engine is does not connect to the center area where the gas tank is located. However outboard of the engine stringers, and outboard of the compartment where the fuel tank is located does connect between the front and rear bilge areas. The ice chest and cockpit drains go to this outboard area. If the boat is in the water it sits low in the stern and all of the water goes to the rear engine bilge. However when on the trailer the boat sits bow low and any water goes forward. I always drain the ice chest while still in the water, that way everything goes aft.
I got my boat completely dried out when at Havasu and have not seen any forward water since.
The yellow color is just from the dirt, crud, and bilge gunk, all old bilge water is always that color.
I also have observed that the rub rail that goes around the gunnel at the transom leaks when it is under water. I would always have some water in the engine bilge, finally figured out that it comes in right at the swim step. I guess that will be a winter project to remove the molding and seal under it.
Dave
Dave
I don't have an anchor locker in my boat. I clean out this compartment with a shop vac/towel and tow it around and more water finds it's way in there. When the boat is at storage it sits bow high and the water just sits in there. The water in my boat never transfers to the rear bilge compartment. NICE DESIGN FOUNTAIN!
i have 1993 32 fountain fever had same problem with water. i called fountain and talked with engineer. i found out that there is a pipe that is supposed to transfer water into engine bilge from front ,mine pipe was there but was not drilled through bulkhead
I fixed the problem by adding a computerized (small) pump to the collection area under the step's going into the cabin , the pump cycles evey minor so,if there is water it pumps it out , if no water resistance it just shuts off ,, I leave it on all winter and it will not run the batt down , it did not fix the boat but it did fix the problem!
RHC
RHC
water
check to make sure that water is not running under wind shield when you wash it or when it rains. It wiil run down dash and into lid that goes to cabin, which is right above the step compartment.
