Go Back   Offshoreonly.com > Owner's Forum > Fountain
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-08-2009, 07:40 PM   #1
fuse panel ?
2004 27 fever . I have found 4 fuses under the dash . was wondering where the rest are ? thanks in advance !
smokediver is offline   Reply With Quote
Old 11-08-2009, 08:59 PM   #2
27 Fountain Fever, 22 Pachanga
I have a 95 and it only has three in it, the rest are breakers under the back seat
EarlyInheritance is offline   Reply With Quote
Sponsored Links
Old 11-08-2009, 10:31 PM   #3
Fountain 27 Fever
Mine's a 2006 - see pic below.
I never looked carefully, but can't remember to have seen any fuse under the dash. Where are they exactly?
And as EarlyIn. says, there are also 6 breakers under the bench seat.
mapism is offline   Reply With Quote
Old 11-08-2009, 11:12 PM   #4
there is a fuse block close to the starboard bulkhead under the dash .. i think it may be for the k-planes .. my nav light in the front doesnt work and i was hoping it was a blown fuse ..
Old 11-09-2009, 09:30 AM   #5
Fountain Family's Avatar
1996, Fountain, 27ft
I have a 1996 27' fever and the fuse all the way to the right keeps blowing. I was wondering what would cause that to blow and what it is to?? I was thinking my cig lighter because it wont work.
Fountain Family is offline   Reply With Quote
Old 11-10-2009, 06:49 PM   #6
http://www.teamshogren.co
blownincome's Avatar
2001 35' Lightning
the switches on the dash each have a built in breaker the fuses under the dash are for dash lights and cig lighter in a 95 the main harness (BOTH wires that go to the keys may have inline 30 amp fuses) and the rest are the main breakers under the back seat.K planes are in this cluster of breakers, if you have no power to the nav light might be a bad connection under the deck seen corrosion in others at that spot Good luck
http://www.coadystowing.com
blownincome is offline   Reply With Quote
Old 11-11-2009, 07:43 AM   #7
I am going to chase it down on Sat. will let you know the outcome .
Old 11-14-2009, 05:44 PM   #8
I went up under the light and jiggled the wires running to the light and now it works , lol .. I was also able to change the oil , gear lube , and a new fuel water seperator ... get her ready for winter boating
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
