unused water pick up's ??
The way I understand it, the holes supply air to the notch, not letting pressure out of holes.... Good example is sticking your finger on top of a straw while it is in your drink and lifting the straw out of the glass. Breaking or relieving the suction at the top of the straw allows the fluid to pass on out the straw. The valves act like your finger at the top of the straw, controlling how fast you relieve the pressure and introduce air to the notch clearing out the stuck water. That was the way it worked on the bass boat, but I didn't have the valve. If one of you 38' or 42' want to trade dead even, I will confirm all this for you
I have also seen on bass boats a tube to the top front of the cavitation plate, was always told the tube sucked air to the prop so the 2stroke could rev up to it's power band. My bass boat days are about 15 years ago, so not sure if that's the case now. If fountain put them there, they're there for performance
Now I know why I have several unused dumps on the side of the boat. Just found out that my Hose's are capped also. So when I get the boat out of storage I should run a hose from the pick-ups to the dumps.
