Toilet issue with my 38 foot Fountain Lightening
Hi, all, I have a quick question.
If the reservoir for the holding tank is full or near full, would the head no longer have suction? My marina has been having issues with their pump out equipment so I think this could be the problem. Recently I drained some of the water using the sink because it began to smell so I thought I would flush it out a bit which obviously filled up my holding tank which is when I noticed that the suction disappeared.
Am I assuming correct with this?
Thanks a million for your feedback
Barry
Barry
I managed to get a proper pump out and the toilet works just fine. I didn't realize how small the holding tank for the head really was lol
Regards
Barry
Regards
Barry
The holding tank has a level sensor, if it is full, it will not activate the suction pump.
Ours stopped too, couldn't believe it was full so checked the relay, cleaned contacts etc, hot wired it and it would work.
Finally opened the top (really was trying to avoid that lol) and it was full.
Pumped out and works fine; I flushed the toilet a couple times while they pumped it out to break suction and get some "flow through" so the dock suction was not being defeated by super vacuum in the tank
Hi Xwing,
Thanks for your feedback, I realized it was just full as well however, very pleased that I did not have open that sucker up LOL
Question: Do your engines use Coolant "orange" one? if so, do you run straight coolant or diluted 50/50. Ive only used the non diluted orange stuff however accidentally purchased a diluted bottle 50/50. Although orange, its a real pale orange hence the dilution and not sure if I should return it or if it would be safe to run with.
Thanks in advance
Barry
Thanks in advance
Barry
Hmmm I have 525's in mine and noticed the previous owner used the orange without dilution. Not sure if he wasn't sure what he was doing or if the 525,s require that stuff straight up!
I'll consult the Merc manual for the motors, it just came in today.
Thanks again and have a super weekend!
Barry
Barry
