charging battery with booster port under seat?
I am adding shore power and the charger I have can charge up to 3 banks independently.
When I used the charge port I just set it up in the mode that gives you higher current by using two of the independent chargers. Independent is better as the charger can tell a difference in each of the batteries but for what this guy wants to do the charge port worked fine for me.
Alright.. so trickle charger on the jumper port is what ill do. Wrecked agm blue top optima battery due to letting it sit dead too often.
I had to replace the Anderson plug also.. pretty easy to find them online or forklift supplier.
