charging battery with booster port under seat? >
Old 04-16-2014, 07:38 PM
I am adding shore power and the charger I have can charge up to 3 banks independently.
When I used the charge port I just set it up in the mode that gives you higher current by using two of the independent chargers. Independent is better as the charger can tell a difference in each of the batteries but for what this guy wants to do the charge port worked fine for me.
You have to start putting it together first Phil. Haha
Crude Intentions is offline
Old 04-16-2014, 08:55 PM
Received 1,336 Likes on 745 Posts
Hey I put the cables in Saturday!
Thread high jack,,,,,,,
Wildman_grafix is offline
Old 04-16-2014, 10:06 PM
Drag it to my house. Or ill come get it. Ill put it together and use for it ya!! Haha
Old 04-17-2014, 01:15 AM
Alright.. so trickle charger on the jumper port is what ill do. Wrecked agm blue top optima battery due to letting it sit dead too often.
I had to replace the Anderson plug also.. pretty easy to find them online or forklift supplier.
breakitout is offline
Old 04-17-2014, 06:51 AM
Ginger or Mary Ann?
US1 Fountain's Avatar
Use a float charger if you are just wanting to keep them topped off.
US1 Fountain is offline
Old 04-17-2014, 07:48 AM
Originally Posted by Cole2534
Any idea where I can get one of these plugs? I'd like to make up some jumper cables since I don't have the factory ones.
I just bought some at a Interstate batteries store and the crimped them and made the cables up for me. So if you have one close try them.
Jamie77905 is offline
Old 04-17-2014, 10:24 AM
I ordered a plug from eBay. Ill probably half a$$ crimp and then fill the lugs with solder.
Cole2534 is offline
Old 04-17-2014, 10:27 AM
Tried that.. couldn't heat the plug enough to get the solder to stick..
HyFive578 is offline
Old 04-21-2014, 05:15 PM
Did you use a torch? That's how I usually do large solder jobs.
Cole2534 is offline
Old 04-29-2014, 11:47 AM
I used a 2 amp trickle charger connected to the jumper cable port most all winter on mine, it worked great.
253 is offline
