This must be the reason my new depth gauge does not register (95 Fever). I glued it right next to the old one but no bueno. Has anyone had any luck "chiseling" out the old ones in this situation leaving the existing little tube they filled in intact and replacing them?
What is the diameter? Maybe a hole saw would work? Just make sure you remove the center drill after starting the cut. Not good to drill through the hull.
