Help on thrown blade
1 Post
Threw a blade on a mercury racing 5 blade 17.5 x 36 pitch.. 21 degree rake..850 hp prop...running 800 hp thru it. Looking at the hub where blade broke off..looks like it was a manufacturer flaw..any help from previous experience would be helpful.
I by no means am an expert in metals but have seen a few different failures throughout the years.....the black/dark rings looks like a fatigue failure are and the rest is a fast fracture...not sure if anyone could have caught that unless the parts were x-rayed and there may have been a pocket of air or something caught inside the metal allowing it to weaken and fatigue....
-Wally
-Wally
1 Post
It could very well have been a defect in the material, but unless you have the other piece, or you have a big void in the hub that you have on hand showing where it could have caused the failure, i don't know if you could prove it a defect. but again i am no expert in metallurgy....may want to find a company that specializes in that to see if they could do a failure analysis on it....
-Wally
-Wally
That black area is what they refer to as "beaching" i believe....you can see the rings from the metal fatiguing each ring is the progression of the fracture...the center point is where it started from....so if you have a void there then it could indicate there was a pocket of air or contamination trapped in the metal that could have caused the failure....
-Wally
-Wally
[ATTACH=CONFIG]552481[/ATTACH]I lost a blade on a Mercury 850 h.p. 17 X 35 pitch. Similar break and my GoPro caught the blade in midair. Expensive picture but I did have a nick on the blade that I should have addressed.
