Who has supercharged their STOCK 350?
Diamond Member #001
Re: Who has supercharged their STOCK 350?
It was a 5.8 FSi (injected). Never got a chance to run it under boost.
Didn't Uncle Toys do it with a Whipple and blew engines????
http://www.offshoreonly.com/forums/s...ad.php?t=29806
http://www.offshoreonly.com/forums/s...ad.php?t=28878
http://www.offshoreonly.com/forums/s...ad.php?t=32260
Member #154
No problem.....since that whole situation, we haven't seen much of Uncle Toys around here.........
Diamond Member #001
Originally Posted by noboat
C Spray, how were richening up the fuel mixture to compensate for the added blower?
You'll want to talk to someone who knows something about ECM's in case you have to retard spark. There should be plenty of experts on that on the board here.
Uncle Toys boat is on the market.
https://www.eliminatorboat.com/F2/Used.cfm?Page=Photo Archive&PhotoID=67&Change=NO
I have a 2000 Donzi 22ZX with a 350 mag mpi. I put on a procharger 4 years ago and have had no problems at all. We boat almost every weekend and live in Florida. I have no idea how many hours I have on the boat, but I'm sure I do at least 100 per year. The speed went from 64.5 mph stock to 78.8 on GPS with no other changes except prop. The system puts out 5 psi. Make sure you get a fuel pressure gauge so you can keep an eye on things. You will also need to run 93 octane. I would highly recommend the set up. If you have any questions at all, PM me. I'll be glad to help.
I supercharged a 300 Mercury tempest small block years ago with a wiend 177 at 5 psi of boost on an Alpha. It was a 21' Formula. Once it was dialed in, I ran that setup hard for countless hours with out failure. I do believe that the Tempest had alot of good parts right from Merc though.
Bob
Bob
