bravo x
bravo x
somone tell me what the difference is from a bravo 1 to a bravo 1x. what year did the bravo x come out and is this years x beeter. thanks.
Masher touches my
Re: bravo x
Mercury's New X-Drive
Improvements and redesigns include:
Top cover aluminum bearing chimney is machined shorter for
the new narrower bearing race.
New Near-Net-Forged Upper gears with 18 tooth splines.
Both gears will have thicker web floors.
New thrust bearings and races for driven gears.
New thrust bearings between garter spring and gear.
New clutch cone stamped "H"
New stub yoke (18 spline) with new thick U-Joint Assembly.
New retainer nut and o-ring & seal redesign.
New thrust washer arrangement for larger L18 Shaft
New threaded heavy duty lower bearing chimney
Hardened DriveShaft Splines
New Splined Coupler
With or without low water pick-ups.
Mercury's New XZ-Drive
Heavy Duty Propshaft & Carrier!
New Splined Coupler
Mercury's New XR-Drive
New Near-Net-Forged STRAIGHT TOOTH Upper gears with 18 tooth splines.
New Splined Coupler
New Splined Coupler
New Splined Coupler
New Splined Coupler
Masher touches my
Re: bravo x
Dont ask me what any of that means, I just pulled it off a web site I had seen.......... I think the X drive was made for use with diesel motors and is a little beefier than the regular Bravo 1.
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
rslick
13
06-15-2005 11:54 PM
