bravo x
Old 05-17-2005, 07:31 PM
yesrej's Avatar
Default bravo x
somone tell me what the difference is from a bravo 1 to a bravo 1x. what year did the bravo x come out and is this years x beeter. thanks.
yesrej is offline
Old 05-17-2005, 07:33 PM
Default Re: bravo x
"X" is what was the "XZ": upper with a standard Bravo lower with DWP.
BAM site has an excellent breakdown of the differences.
Rippem is offline
Old 05-17-2005, 11:33 PM
Masher touches my
Outdrive1's Avatar
Default Re: bravo x
Mercury's New X-Drive
Improvements and redesigns include:
Top cover aluminum bearing chimney is machined shorter for
the new narrower bearing race.
New Near-Net-Forged Upper gears with 18 tooth splines.
Both gears will have thicker web floors.
New thrust bearings and races for driven gears.
New thrust bearings between garter spring and gear.
New clutch cone stamped "H"
New stub yoke (18 spline) with new thick U-Joint Assembly.
New retainer nut and o-ring & seal redesign.
New thrust washer arrangement for larger L18 Shaft
New threaded heavy duty lower bearing chimney
Hardened DriveShaft Splines
New Splined Coupler
With or without low water pick-ups.
Mercury's New XZ-Drive
Heavy Duty Propshaft & Carrier!
New Splined Coupler
Mercury's New XR-Drive
New Near-Net-Forged STRAIGHT TOOTH Upper gears with 18 tooth splines.
New Splined Coupler
Outdrive1 is offline
Old 05-17-2005, 11:35 PM
Masher touches my
Outdrive1's Avatar
Default Re: bravo x
Dont ask me what any of that means, I just pulled it off a web site I had seen.......... I think the X drive was made for use with diesel motors and is a little beefier than the regular Bravo 1.
Old 05-18-2005, 04:10 PM
yesrej's Avatar
Default Re: bravo x
I Just What To Know Because I Just Bought A Boat With A Bravo X And Its A 2002. I Didnt Think The X Was Around Then.
yesrej is offline
Old 05-18-2005, 04:44 PM
Default Re: bravo x
yes it was the X was packaged with the 496 HO right from the get.
Rippem is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
Quick Reply: bravo x
