76 superboat fuel sender location
Purchased a 76 24' superboat with a fresh 502 from my uncle. The fuel guage does not work and was wondering if anybody knows were it is located? any help would be great.
jon
jon
Re: 76 superboat fuel sender location
The fuel sender is right on top of the tank under the back seat on my '98 I/O. You might be able to it from the engine compartment without removing the seat.
JV,, where are you located? I just had one go bad on my 21' Superboat. I don't know if they are in the same position? but I can tell you who to call. How many gallon tank?
I am currently located south of baltimore, but move back and forth because my wife is in the military. I boat in the philly region down to baltimore.
I can't see the sender from my engine compartment. The tank is 60 gallons. I will try to call JC on monday about the location unless someone can help me out. If it is in a location were I can't get to it, I might cut a new hole in the rear were it is easy to access.
Ok try this, Is the fuel fill and the vent line located near the rear of the tank,actually 2 1/2" up from the rear edge of the tank, on the starboard side of the centerline??? If it is, my sender was in the middle of the tank, 44" up toward the bow. or from the center of the fuel fill, 41 1/2" up, if you can't see the rear edge of the tank. This is where my sender was located, 60 gallon tank, I would call JC and check it the tank for the 21' and 24' is the same. Or just bring the boat up to Long Island, East Coast Marine changed the sender for me.
It is red on the sides with a white stripe in the middle of it. It is currently powered with a 502/435hp and trs drive. Boat runs great, but needs some little things to complete and paint and upholstry. Lucky me, because I paint, and my step-dad does boat upholstery work.
Now if I can find the location of this damm fuel sender
