Re: Need Ideas for Fan for Stereo Amps ?
The first thing I see thats a problem is that the amps are mounted upside down. The heat is being traped in the amp.
I think if you read the instructions it clearly states not to mount like that. |
I think if you read the instructions it clearly states not to mount like that. If at all possible remount them properly, and the radio shack PC fans work well. I run separate power wire on a relay for the amp trigger on/off switches, and I tie the fans into that. |
Originally Posted by LubeJobs42
I had about 4,000 watts in one of my cars, and had a lot of problems with heat in the trunk. I got 6" Bruchless fans and mounted them on the side of the amps (where the wires go) and they would blow through the fins, it made all the differance. Make sure you get brushless fans, otherwise you will have engine noise. Here is a picture of what you should use. they come in 4" and 6", you may be able to find smaller. Have them wired so when the system is powered on, so are the fans.
Ill ck on the mounting of the amps. Thanks |
