If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 2 of 2
  1. #1
    Registered GregP's Avatar
    My Boats:
    1989 Scorpion 32 CC
    Join Date
    Apr 2001
    Annapolis MD
    How to find fuel tank outlet plate?
    My boat does not have access plates in the floor to get to the fuel tank outlets. I'd like to put some in (so you don't have to remove the floor panels, console, and all the wiring/rigging to access them). Problem is I don't know "exactly" where they are.
    The manufacturer has retired (1989 Scorpion) so I can't just call the factory and ask, and I've never seen a photo of the boat or a sister ship without the liner in. I know about where it has to be (dual tanks so one on each side near the back edge of the floor panel), but am wondering if there is any trick to find "exactly" where they are so I'm sure to be close enough if I cut a hole and install an access. The tanks are foamed in. I tried running my bore scope up through one of the unused rigging tubes that runs into the area where the tanks are but all I get is foam as far as I can reach (24").
    Anyone know some sneaky way to figure out where the outlets on the tanks are at?
  2. #2
    Ed is offline
    Gold Member Gold Member
    Join Date
    Oct 2000
    Ft.Lauderdale, Fl.
    Re: How to find fuel tank outlet plate?
    There's only one way to accomplish this task properly. Start taking apart the cockpit & the cockpit sole(floor). Mark the locations for deckplates(inspection ports), cut out the holes & install them. For the record, all boat manufacturers have always been required by the United States Coast Guard to install fuel connection access plates, even in 1989. This goes for the the fuel fill hose connections at both the tank AND the deck fill, as well as both ends of the fuel vent line. Ed
Similar Threads
  1. Trying To Find This Breather Tank
    By zimm1978 in forum General Boating Discussion
    Last Post: 03-26-2008, 01:32 PM
  2. Where to get external fuel pump block off plate?
    By zimm17 in forum General Q & A
    Last Post: 04-05-2007, 11:43 AM
  3. Fuel sender/fuel tank ground?
    By JGB in forum General Q & A
    Last Post: 09-24-2004, 01:44 PM
  4. Fuel tank, fuel sender ground?
    By JGB in forum Cigarette
    Last Post: 09-24-2004, 09:21 AM
  5. Small Fuel Tank -Fuel Gauge Problem ?
    By JROMY in forum General Q & A
    Last Post: 07-23-2003, 07:29 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
