a/c problems
Was out on the river this weekend and the a/c worked for a little while but then it flash a code of HPF.manuel says its high pressure freon.i turned it off then back on and about every 2 minutes it does it again.It was 89 in the cabin.I release some pressure from the vavle but didn't make a differance.Anyone know what the fix is.Do i need freon ?
Re: a/c problems
You need a new boat.....I'll give you a few bucks for your POS :eek: :D
If you see water pumping out and the compressor kick in then it's over my head.....good luck! |
Re: a/c problems
Re: a/c problems
i'll sell you a used window unit, slight damage :eek: :D:
Re: a/c problems
was the water circulating? If the pump stopped, It will cause pressure to build since it cant get rid of the heat.
Re: a/c problems
It means high pressure-freon. For some reason your cooling water is not going through the unit. Either the system is clogged or the pump is done-you may also have an airlock in the system. Try opening the sea strainer and see if there is water flow there.
Re: a/c problems
I have water coming through and it cycles but it just doesn't cool down.thinking it needs recharged with freon.i have a friend coming over today to put gauges on it and check for leaks and recharge if needed.
Re: a/c problems
Re: a/c problems
