Mercruiser 320 EFIs
Re: Mercruiser 320 EFIs
Cuda's Minx was a yachet tender in it's previous life.. Low hours, but may not have been maintained well as far as flushing goes.
Engine ran strong before the meltdown, I would bet they would run real well in your boat. I'm not familiar with the injection issues Cuda mentioned, but it seems to me if they are overfueling it would be fixable with some injector tweaking..??
24*- nice set up, If they are running well let em' rip. I had one that ran awsome 5500 rpm all day long, and one that would lean out and blow up when pushed hard. I loved the look and the fuel efficiency of them and I may even go back to them with a modern ECU (true MPI) not batch fire like they are stock. The injection parts are not a Mercury specific item. heres a little secret....injectors are from Porsche 928. I have a guy here in CT that ran all the part #'s and can get anything you need. The TPS is no longer available so we are working on some sort of spacer/adaptor to mount on the end of the throttle shaft. Let me know if I can help you out, I have a bunch of info I've collected over the past 5 years.
Thanks guys.....
Batch fire......? I've never heard that term. Funny about those injectors. I own and operate a Porsche repair shop in Minneapolis and I noticed that the fuel pumps in the boat are the same as in my '78 911......
Now I just need to get educated on Chevy/Mercruiser stuff. Is it true these are 4 bolt main blocks?
I was thinking I could update to the MPI set up some day.....sounds like big money?.....might be worth it though.
Sonic......when you say running hard what does that mean? How long can I run this wide open?......It does seem to turn 5500 rpm also.
BTW: I'm running it on Lake Minnetonka just outside of Minneapolis, Minnesota.
Thanks,
Aaron
Thanks,
Aaron
Originally Posted by 24degrees
Thanks guys.....
Thanks,
Aaron
Thanks,
Aaron
I had sold a couple of Checkmates back in the day, that had these motors w/Alpha SS drives. They ran real well....however, even at the time(early '90's), they had a reputation for electrical gremlins in the computer, and oil consumption. I remember that they were an adaptation of the short-lived Crossfire injection that was used on some Vettes around the same time. I recall a particular 21 Checkmate that would run 70+mph w/the 320/Apha SS pkg. if you had the stones to hold on.
Hugh
Hugh
Thanks guys.....
Thanks,
Aaron
Thanks,
Aaron
A few points of interest.
First, the throttle body/ plemum are around, I know where 2 are. The injectors, regulator and the like are bosch off the shelf parts.
The ECU can be replicated by Repair in Fla.
As for the engines, they run very very well, they only have issues when people that fool with them have no idea what they are playing with.
This is the same induction system that is on the merc Hi-per outbaord motors, the 2.4 and 2.5 series.
When it was mentioned that the injectors are fired in batched pairs what is ment is that two injectors are fired at the same time. This is not an uncommon thing with EFI. The best systems run sequential fuel injection, each injector fires on it's own.
I know of a lot of 320 EFI's that still are around and still run very strong. Hell the alpha SS drive that it came with it VERY saught after.
Setup Setup Setup, and they work great once correct.
RT
RT
