| OSO Sponsor |
| OSO Sponsor |
10-06-2005, 01:20 AM
XR Nose cone or no nose cone???
Trying to figure out if I should install a nose cone on my 05 Xr drive. Running in the mid 90's and the boat likes alot trim to reach best speeds with a Bravo1 prop. Only a couple trips out on the new boat, I'm still looking for the correct pitch prop but wondering about nose cones on the newer bravo's. I ran one on every other boat I've had. Maybe the newer Bravo's are better suited to higher speeds? Which one doesn't create stern lift?
10-06-2005, 01:28 AM
WHYC / NIOC
42 Fountain/370 SeaRay
Re: XR Nose cone or no nose cone???
you won't be able to keep the paint on it...get an IMCO lower case
Saris Racing 800SC
Bmax/-2 IMCO's
Cryo Gear sets
IMCO Boxes
MitcherT
Livorsi
10-06-2005, 02:08 AM
Is it nuetral or does it create + or - lift?
10-06-2005, 07:05 AM
2001 Superboat Y2K
I'm looking for the same info. However I'm in the low 80's....for now  Are you spinning left or right?
10-06-2005, 10:07 AM
R.I.P. Lucky
39 Nortech CC
I ran stock Xzs on my boat after repowering, would run 99 @ 5000 rpms and 96 @ 5600, changed lowers to IMCOs Ran 110 with the same props. I had the IMCO lowers painted and ran them for two years, never lost any paint.
10-06-2005, 11:17 AM
FD,
Are you going to Havasu this weekend? If so, let's hookup, I want to see the boat!
Gerard
10-06-2005, 11:19 AM
Quote:
WOW !! That is a good pick up. Is that with a regular imco lower or a shortie?
10-06-2005, 11:51 AM
R.I.P. Lucky
39 Nortech CC
Regular IMCOs, It was a triple engine set up and only three blade props would work, 4 and 5 blades had to much blade area in the water and had porposing issues. The IMCOs cleared up the blowout issue over 100mph. Also the water intakes were smaller and helped with water pressure.
10-06-2005, 01:29 PM
Quote:
I started with a lefty. Now I have a right hand 30 Bravo1.
10-06-2005, 01:30 PM
Quote:
Originally Posted by Semper Fi
FD,
Gerard
Sorry I will not be going out this weekend. I have other plans. Maybe the one after.
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Which Nose Cone
CN24 |
General Q & A |
7 |
11-15-2006 11:06 PM |
Nose Cone
BY U BOY |
General Q & A |
11 |
08-29-2006 09:58 AM |
Best Nose Cone
SkiDoc |
General Q & A |
32 |
01-30-2005 12:24 AM |
nose cone
edy |
General Q & A |
4 |
08-07-2003 03:36 PM |
