XR Nose cone or no nose cone??? >
Old 10-06-2005, 12:20 AM
FASTERDAMITT's Avatar
Default XR Nose cone or no nose cone???
Trying to figure out if I should install a nose cone on my 05 Xr drive. Running in the mid 90's and the boat likes alot trim to reach best speeds with a Bravo1 prop. Only a couple trips out on the new boat, I'm still looking for the correct pitch prop but wondering about nose cones on the newer bravo's. I ran one on every other boat I've had. Maybe the newer Bravo's are better suited to higher speeds? Which one doesn't create stern lift?
FASTERDAMITT is offline
Old 10-06-2005, 12:28 AM
Back4More's Avatar
Default Re: XR Nose cone or no nose cone???
you won't be able to keep the paint on it...get an IMCO lower case
Back4More is offline
Old 10-06-2005, 01:08 AM
Is it nuetral or does it create + or - lift?
Old 10-06-2005, 06:05 AM
Pure Energy's Avatar
I'm looking for the same info. However I'm in the low 80's....for now Are you spinning left or right?
Pure Energy is offline
Old 10-06-2005, 09:07 AM
BBB725's Avatar
I ran stock Xzs on my boat after repowering, would run 99 @ 5000 rpms and 96 @ 5600, changed lowers to IMCOs Ran 110 with the same props. I had the IMCO lowers painted and ran them for two years, never lost any paint.
BBB725 is offline
Old 10-06-2005, 10:17 AM
Semper Fi's Avatar
FD,
Are you going to Havasu this weekend? If so, let's hookup, I want to see the boat!
Gerard
Semper Fi is offline
302Sport (06-03-2020)
Old 10-06-2005, 10:19 AM
gsmith9898's Avatar
WOW !! That is a good pick up. Is that with a regular imco lower or a shortie?
gsmith9898 is offline
Old 10-06-2005, 10:51 AM
BBB725's Avatar
Regular IMCOs, It was a triple engine set up and only three blade props would work, 4 and 5 blades had to much blade area in the water and had porposing issues. The IMCOs cleared up the blowout issue over 100mph. Also the water intakes were smaller and helped with water pressure.
BBB725 is offline
Old 10-06-2005, 12:29 PM
I started with a lefty. Now I have a right hand 30 Bravo1.
Old 10-06-2005, 12:30 PM
Originally Posted by Semper Fi
FD,
Gerard
Sorry I will not be going out this weekend. I have other plans. Maybe the one after.
Quick Reply: XR Nose cone or no nose cone???
