greatest apache ever?
#201
Re: greatest apache ever?
Magnum I will always run her, thats what she was built for, will have to hook up down toward Carl's this coming summer. Take care, Steve.
#202
Originally Posted by el indio
dont show it DRIVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!m.m...
#204
Originally Posted by ApacheCarl
Gee, I thought I put it on the boat lift every summer to help hold up the seawall. MM, you have an award winning grasp of the obvious.
#207
and a nice sea wall at that!30 hours in a summer is not alot of boating in my book..........mark..........p.s...how fast did your boat run with 800 mercs?..............i like you flat top fuel tanks......they dont gather water on the top rear. right?.....m.m......
Boat ran 88 mph with the Merc 800's, fresh water, never ran it in salt with those motors. When the boat was originally built the drives were about an inch to low. Warhawk was the first 41 Apache built with #6 drives, so mounting height was not an exact science back then. As more boats were built the drives were mounted higher.
WarHawk will go faster when I get the drive height dailed in. Calculated my slip at 16% WOT. 21% at 4000 rpm . Drives are a 1/2"- 3/4" to high, i'm making some 1/2" and 3/4" spacers now and will try them this winter/spring. Went a little high during the rebuild, but, I'd rather be a little high to start, mucho easier going down. Should go close to 100 when I'm done, but as of right now, its 96 mph. Too much slip.
Yes, the tanks were made flat on top and the area from the outside of the tank to the hull is sloped in a little so no water sits back there. That standing water in those areas was a pet peeve of mine.
I also had the the fill tubes on the tanks extend 1.5" into the tank. This keeps you from over filling the tanks and having fuel burb out of the breathers all the time. Lost a little capacity, maybe 5 gallons, but fuel burn is so low on the injected motors, its not an issue. With 4 tanks I still have about a 160 mile range, which is all I need(any longer range would just cause me to get lost )
#208
Boat ran 88 mph with the Merc 800's, fresh water, never ran it in salt with those motors. )
Amazing what a little weight will do huh? Your 800's are now pushing my 32 skater 135. Your boat looked great at red dock when I met you this fall. Keep up the testing 100 is a fun benchmark even if you only do it once. NK
#209
Originally Posted by Nauti Kitty
Carl
#210
30 hours in two months? I was thinking about this yesterday when I was loading my boat up for S.Fl., I checked th hour meters and I put a whopping 44 hours on mine since Aug. of '04. Man, I'm gonna were this thing out quickly. I guess when you boat on a lake that you can cover from one end to the other in 30 minutes you don't put alot of time on them
Robert
Robert
